I am now on my third belt within 500kms of driving.. First one I replaced because it was squeeling a lot when I bought the car.
Second one started to squeel and then a friend sprayed WD-40 on it so it burned out & snapped.
I am third belt in & I can hear it starting to squeel again.
If the bearings in the water pump or alternator are going will it cause this? If so, how do i determine which one it is?
Is there anything else it may be?
thank you all!
thank you all!
