Instrument Cluster only thing that doesn't light up?
  • Instrument Cluster only thing that doesn't light up?
    Okay guys, new issue with Festiclese. My dash lights stopped working. I have the dimmer switch bypassed (Red/white to ground). My radio lights and tail lights work. With the current set-up it was fine but all of a sudden it stopped working. Room fuse and tail fuse are good. CEL, Defog, etc lights work. It's just the Tach light and Speedo light. Any ideas?
    Current cars:
    Also, I got voltage going to the dimmer switch wires. So I know it isn't broke from there.
    Current cars:
      Have you checked the bulbs? There are 2 194s behind and 4 74s total. All of mine went after a good smack to the top of the dash once. Also check the cluster circuit board for any broken printed leads.
      Sent from the bathroom via crapatalk
      91 L 5sp "The Silver Bullet" B6, Brake/Susp Swapped Build Thread
      92 L 5sp "Red" RIP
      95 Grand Prix SE DD
      Wife's Stuff:
      89 L 5sp "Carby Car"
      97 Aspire auto "Pink Panther"
      Build Thread
      Spring 2013 IndyStiva:
      http://www.fordfestiva.com/forums/sh...eet-April-20th
        lmao... i have to slap the top of my dash every night to tun on my cluster lights... ive pulled the circuit board out and checked it a few times but i cant find anyhting wrong with it... let us know if you find a solution.
          Have you messed with your radio wiring lately? And are you sure your heater lights are on? My dash lights and heater lights shorted out after I installed a new cd player. Still haven't found a solution, I just wired in a blue led light bar inside the cluster with the illumination wire for the radio lol..
          I've tried 2 other dimmer switches since then and the light just don't work, i doubt my problem has anything to do with a faulty dimmer switch.
          2008 Kia Rio- new beater
          1993 Festiva- Fiona, DD
          1997 Aspire- Babyspire, DD
          1994 Aspire - Project Kiazord
          1994 Aspire- Crustyspire, RIP
            It just started working today, which is more annoying then them being broken. Stuff needs to either stay broken or working.
            Current cars:
              Hahaha that is more frustrating than anything
              -M3NTAL MARK! Woo!!
                Imagine being a tech at a dealer and that happen... its even worse when it under warranty.
                Im not driving a Festiva because I'm poor. I drive a Festiva because i want to!
                Dennis
                93 GL In progress BP/hydro G
                15 Mitsubishi Mirage daily
                88 Dakota tow pig
