93 festiva GL 1.3 Hot or cold engine runs with power for the first minute or so, then, no power, it will stay running but wont accelerate. What I do while still rolling is turn the key off and on real fast and then the power is back for a minute or so. Just keep doing this till you get home. This solution is for a festiva/mazda guy help! I will take any and all phone calls and even buy lunch. John 815-465-6604
Replaced brain, vap or “vaf”,map, fuel pressure regulator,injectors tps,iac,,fuel relay ,high speed relay, igniter, condenser (capacitor) .coil. complete distributor included was the crankshaft positioning sensor, cap, wires, rotor, 02 sensor, fuel pump, fuel filter, radiator temp sensor, engine temp sensor. checked timing belt,checked crank and cam alignment. Main relay sounds like its working. Replaced all vacuums, cant find any vacuum leaks on intake. Tried adjusting the TPS, Attempted to adjust tming but was never able to get the marks near the timing guage. Running out of things to replace
