my car (now that I fixed the charging problem) will stall when I put it in gear with the brake applied.... and when I do get it in gear the car has no power or acceleration ESPECIALLY on hills.... right now I cannot get the car out of my yard under its own power..... it runs and idles fine, I can even give it gas when in park and neutral, it will rev. Any suggestions?????
stalls in gear when brake applied (Automatic)
timing...Trees aren't kind to me...
I'll check into getting into a new set of wires, don't know when they were changed last..... I did find oil in the TB (just a little). I hope it's not the timing (even though these are non-interference) because I just hate timing engines while in the car...Andrew Walker
Current Daily Driver:
89 Nissan D21 SE V6 5 speed 4x4
Projects in the works:
84 Mercedes Benz 300D(T)(Baby) currently awaiting transmission transplant/ full on restoration
If it idles fine without your foot on the brake and promptly stalls when you press on the brake pedal, a very good culprit is a defective brake booster. The brake booster is the big pie pan shape vessel behind the master cylinder. Sometimes they leak vacuum and cause the engine to stall. If you want to make sure that is the culprit, remove the vacuum line going to it and plug it (the side that goes to the engine), then start the car and press on the brake - If it runs normal, then it is the booster (aka vacuum pod). Good Luck!
^^^ looking to see if I can get a plug big enough to plug it, but using something about that size didn't really help....Andrew Walker
it's not the booster if it stalls while going into gear. Andrew, buy, borrow or steal a vaccum gauge and report the readings.Trees aren't kind to me...
Did it have this problem before you fixed the charging problem?
If not go back and double check that something didn't get accidentally bumped and unplugged, vac hose or electrical plug.Hotrod Forums Directory * D&D Discbrakes 61-67 Econoline Conversions
I don't know, as I could never get the car to run long enough to figure this problem out, I believe it did, but like I said there's no real way of telling since I couldn't get the car to that point prior to fixing the chargining problemAndrew Walker
Will likely be borrowing one this evening....Originally posted by FestYboy View Postit's not the booster if it stalls while going into gear. Andrew, buy, borrow or steal a vaccum gauge and report the readings.Andrew Walker
I didn't get the vacuum tester today, but I have arranged to take a friend to and from a doctor's appointment, he has a whole slew of tools (some of which will make you wonder) and I'm also working on removing a fuel pump to be transplanted into the ranger I intend to purchase from him....Andrew Walker
Still haven't had a chance to work on it, I'm looking @ probably monday since the friend I'm getting the tools from couldn't give them to me the other day and I've got a side job with him tomorrow
was in Charlotte,NC today (left at 6 and ran straight down did some running and came back) now i'm beat....
Andrew Walker
