I bought an '89 wiring and vac manual on ebay a few days ago but don't know when it will arrive.
Temperature sensor
Originally posted by Ford Fester View PostI have the 89 but im 600 miles awayill look saturday if this is not solved by then
Originally posted by georgeb View PostI bought an '89 wiring and vac manual on ebay a few days ago but don't know when it will arrive.youtube.com/neanderpaul 88 festiva LX w/BP G25 MR 5 speed waiting for wiring- 93 Festiva GL auto w/ air, waiting for B6t/G4A-HL - 98 Nissan Quest - 02 Mazda protege 5 wife's DD
Radiator Coolant Temp switch. Input to PCM, pin 1L, light green wire. Black wire at switch is ground. Switch is closed at 63*F and above. Used to indicate cold weather operation, primarily cold-start (choke-function emulation).Jim DeAngelis
Originally posted by GenevaDirt View Postgot an answer for you from Jim....it is the fan control. He does not remember if when unplugged the fan stays running or does not run at all. If it is like the one up top...I would say the fan would just always run when it is unplugged.Jim DeAngelis
Originally posted by FB71 View PostRadiator Coolant Temp switch. Input to PCM, pin 1L, light green wire. Black wire at switch is ground. Switch is closed at 63*F and above. Used to indicate cold weather operation, primarily cold-start (choke-function emulation).I knew it wasn't for the fan or temp sender because I had it unplugged on Babystiva for a while and those both worked fine. Figured it was something to do with cold start/choke
No festiva for me ATM...
Originally posted by FB71 View Postjust to clarify... I was half asleep when Willie asked me!"FLTG4LIFE" @FINALLEVEL , "PBH"
Originally posted by htchbck View PostBOOM! I was right a week ago!I knew it wasn't for the fan or temp sender because I had it unplugged on Babystiva for a while and those both worked fine. Figured it was something to do with cold start/choke
I know you've been through several different rads looking for the right one, but I promise the AZ one is a direct fit. I've used them on two carb'd cars with that bottom switch, and on both the switch screwed on perfectly after removing the plastic plug. One of them is in Babystive right now actually. Barring that, maybe you can find a switch that is smaller and closes around 63ish degrees. Then drill and tap the current plastic plug to accept it? Might have to switch the terminals on the wires to fit the new switch as well. Or just short the wires together and then stop driving the car after it starts getting cold outside? :lol: As long as the wires are shorted together it shouldn't affect anything till fall temps get here, so you have a little time to sort it out at leastNo festiva for me ATM...
Originally posted by FB71 View PostRadiator Coolant Temp switch. Input to PCM, pin 1L, light green wire. Black wire at switch is ground. Switch is closed at 63*F and above. Used to indicate cold weather operation, primarily cold-start (choke-function emulation).Some people like to read fiction,I prefer to read repair manuals. Weird I know-
Paul works for advance auto, so buying an auto zone rad might be sac-religious-Greg
Redneck Engineer
FOTY - '09
