Just came across this on ebay quite cheap so I ordered one you can use the 30-40-30 fuses, but the power line has to be separated and bladed into each end. They have other sizes, too.
The fuel pump in my 91 has gone silent and the car isn't starting. So I've ordered a new pump - less than $11 delivered and will first be attempting to dismantle and resurface the fuse box- I've had some cartride fuses in that work fairly well,
but its still "fussyble"! Gotta clean it or try this block. I'm wondering if I can wire my cooling fan switch into terminal four, as the harness is mysteriously altered and doesn't seem to have a normal fan connector.
Also just got a new heater blower fan the old one just freezes up from non-use I hope. Also got some rebuilt front calipers and have the pads and hardware. When I get this car on the road, it should be sorted out.
