On Friday, 09Sep, I changed transmission fluid in my Aspire. This fluid had been in the car for about one month and 640 miles. It came out looking very clean and there was much less grit in the drain plug hole after draining the fluid this time.
There was nothing that settled to the bottom of the drain pan and the magnets I placed in the pan showed hardly any signs of metal powder.
Unfortunately, looking closely at the fluid in direct sunlight, I could see hundreds of shiny particles suspended in the fluid. My guess is they are soft metal, like brass, used in synchronizers. I hate to think they could be the result of only 600 miles of easy shifting that I gave it. Hope some of them could be left over from the earlier fluid.
The shifting was not improved by this change and when I shift I have to push pretty hard to get the synchronizers to do their thing. I assume they were originally provided with a roughened surface to prevent their slipping too easily. My guess is that surface was floating in the ATF I drained out and the mating surfaces are worn pretty smooth.
I believe this fresh ATF is killing my transmission. I have only 20 miles on this new fluid, but will not drive the car until I put a different fluid in it.
Brian has suggested two fluids for use in my transmission. I'm tempted to try them both before deciding which one feels the best to me. The excellent Red Line White Paper Brian linked to impressed me so much that in case of a tie, I would go with Red Line MTL. So I think I'll start with Pennzoil "Synchromesh" before trying MTL, since at this point MTL appears to be the one I'll end up selecting. Besides, according to Brian, I should be able to get the Pennzoil "Synchromesh" fluid at WalMart and can get this process started sooner.
I also want to order one of the Dimple Magnetic Drain Plugs which may take a few days to receive, so an extra change will give me the use of my car while waiting for the plug to arrive.
I invite your comments and suggestions.
I did fill an aspire with left over royal purple atf from my srt-4 and it did fine until i sold it. Ill get some thicker stuff when its time to roll out.
