My Automatic 93 won't shift into Drive unless you first shift into Second. I know it's a bushing, but the Festiva bushings are obsolete, so what are my options? Can anybody help by giving me a part number for a Mazda, Aspire, etc.? Thanks!
Worn Bushing
nvm, i didn't read the auto part >.<Last edited by zoom zoom; 09-07-2011, 06:26 PM.2008 Kia Rio- new beater
1993 Festiva- Fiona, DD
1997 Aspire- Babyspire, DD
1994 Aspire - Project Kiazord
1994 Aspire- Crustyspire, RIP
^^ that information is for a manual shifter. He has an auto so they are completely different.89 Festiva L Carby 4 Speed... RIP. Evicted and Scrapped. I HATE MY FAMILY
Facebook Me!
it is just a matter of adjustment....no bushings. I had the same problem with one I bought and it is always a little off when you swap a tranny or something. Very easy fix....just need to loosen a nut inside on the shifter and adjust accordingly and then tighten."FLTG4LIFE" @FINALLEVEL , "PBH"
There is a bushing where the cable connects to the selector shaft. When that bushing wears out, it will cause exactly the symptom listed by the OP. Unfortunately, I do not have any replacement information.Jim DeAngelis
kittens give Morbo gas!!
really....didn't notice that....I know mine was doing the same thing and just needed adjusted.Originally posted by FB71 View PostThere is a bushing where the cable connects to the selector shaft. When that bushing wears out, it will cause exactly the symptom listed by the OP. Unfortunately, I do not have any replacement information."FLTG4LIFE" @FINALLEVEL , "PBH"
yup. Hula had that problem before I swapped her to a 5spd. Found the bushing that was supposed to be in the selector shaft arm was missing.Jim DeAngelis
are you talking about inside the case?Originally posted by FB71 View Postyup. Hula had that problem before I swapped her to a 5spd. Found the bushing that was supposed to be in the selector shaft arm was missing."FLTG4LIFE" @FINALLEVEL , "PBH"
just took these out of my 1990 shop manual.....shows a pin only.....I believe that is all that is on both of mine, all I have ever seen anyway.
there's a very thin-walled nylon bushing pressed into the selector shaft arm where the pin passes thru. I'm betting it was not serviced separately, therefore, it would not be called out in the shop manual.Jim DeAngelis
ahhhhhh....lol...I am sure when I took my other one apart I didn't even notice it and I am sure it is part of my driveway.Originally posted by FB71 View Postthere's a very thin-walled nylon bushing pressed into the selector shaft arm where the pin passes thru. I'm betting it was not serviced separately, therefore, it would not be called out in the shop manual."FLTG4LIFE" @FINALLEVEL , "PBH"
Geneva Im having an issue with my shifter and I want to try your fix, can you explain loosen a nut inside the shifter and adjust, I dont understandOriginally posted by GenevaDirt View Postit is just a matter of adjustment....no bushings. I had the same problem with one I bought and it is always a little off when you swap a tranny or something. Very easy fix....just need to loosen a nut inside on the shifter and adjust accordingly and then tighten.91 Festiva GL 236,000 and still going
