96 Aspire tranny problem
  • 96 Aspire tranny problem
    I can't get my 96 Aspire automatic tranny out of park. Any suggestions?
    The switch that unlocks it when you step on the brake might be faulty or out of adjustment.
      Should be a little plastic cap on the shifted console . Remove it and shove a screw driver down the hole ,this will basically bypass the ignition lock . If that doesn't work remove the shifted cable end off the trans and see if it will move there , make sure its not running .
      New build on the way .
        On festivas there is a fuse that when blown will prevent you from shifting out of park.
