I can't get my 96 Aspire automatic tranny out of park. Any suggestions?
96 Aspire tranny problem
Should be a little plastic cap on the shifted console . Remove it and shove a screw driver down the hole ,this will basically bypass the ignition lock . If that doesn't work remove the shifted cable end off the trans and see if it will move there , make sure its not running .New build on the way .
