Fast responses greatly appreciated. My car is at the end of the driveway blocking other vehicles that have to leave in the morning.
I removed my timing belt and put it back on because it was suspected to be off a tooth.
I have the belt back on, but I can not figure out how to order the spacers or which way they should face. I have tried a few configurations and each time I get a high pitched squeal from the timing belt.
My pulley and spacers.
This engine is from a car that had A/C. I do not have the A/C pulley on the engine.
Brass spacer was between pulleys, correct? Crank pulley. Then two thin silver spacers.
Thicker brass spacer.
Larger diameter thin silver spacer.
Smaller diameter spacer.
These two spacers keep rubbing on the timing belt. I have put the smaller one on first and test fit the big one first but it appeared as though it would rub as well.
They both have curves but that changes when the pulley is installed and puts pressure on them. I can not remember how they were when I took them off and there are belt marks on both sides of both of them so I have no idea which one goes where and which way it faces... :cry_smile:
