Compression check
  • Compression check
    What would be considered an acceptable to good compression reading on a stock '88 LX with 173,000 miles. And an ok number between cylinders. Thanks!
    I'm thinking 140 and higher with no more than 15 percent between cylinders.
    Semper Fi til I die!
    1993 Fescort GT 1.8 BP automatic Kia Rio front struts and cut springs Cut Front Festiva springs with Monroe Aspire struts in rear
      with that kind of miles, i would say 120 and higher would be acceptable especially if you aren't burning oil, if you have normal power, then i wouldn't be too worried until you have an issue
      -Aspire brake swap COMPLETE!
        No more than 5% variation among cyclinders.
          less than 10% is considered good. 15% is acceptable.
          Jim DeAngelis
            The numbers are in! 150/140/150/145. Plugs looked good. Replaced plugs and wires anyway.
              looks good!
              Jim DeAngelis
                10/140 = 7%
