What would be considered an acceptable to good compression reading on a stock '88 LX with 173,000 miles. And an ok number between cylinders. Thanks!
Compression check
with that kind of miles, i would say 120 and higher would be acceptable especially if you aren't burning oil, if you have normal power, then i wouldn't be too worried until you have an issue
-Aspire brake swap COMPLETE!
. Plugs looked good. Replaced plugs and wires anyway.
