Originally posted by iceracerdude
CV wont fit into 5 speed trans!
what is the full name for this CD? if it's not yet on torrents we should upload it, should not we?
Good job!, it's all pretty easy from here on in. Just go slow and be carefull. Did you ever pick up a proper drift pin punch, or think to make one out of a junk philips screwdriver?
Yes, It sort of just fell out like you said it would, I did not get a good look at where it came from.Originally posted by iceracerdude View PostOk in this picture, down at the bottom left near the edge about an inch from one of the case bolt holes, and just across from the shift shafts, is that small hole facing down.
I believe that's where that slender pin came from. Did you find that second, shorter, fatter pin between the two shift shafts?
X2... nice to see all the pics and instructions from iceracer. Hopefully soon I'll be attempting to build two good MTXs out of two broken ones and a third one that is completely torn down (but supposedly complete) that I'll be scavenging for parts.Originally posted by BigElCat View PostThis tutorial should become a Sticky
Ok in this picture, down at the bottom left near the edge about an inch from one of the case bolt holes, and just across from the shift shafts, is that small hole facing down.Originally posted by jjk1224 View Post
I have everything apart, in the morning I am going to clean the case and parts good and re-assemble it. I am still lost as to where that smaller pin needs to go, and where do I need to put the other 3/8" pin? I am glad my nightmare is almost finally over. Working on transmissions is one of the only things automotive related I have always been in the dark about. I want to thank everyone who helped and directly or indirectly convinced me to tackle this project. At this point there is not a single part of my festy that I have not put a wrench to!
This tutorial should become a Sticky, unless some bonehead intrrupts with a bunch of,,,err,,,err.....okay, okay I'm out of here.
All of them, remember the reason you're doing this is so that you can slide the fork rods straight up and out, then remove the forks, then the gear clusters, in that order. First remove the remaining springs, bolts, and balls, otherwise that last one will fight the removal of that third shift shaft. Did you remember to take pictures of this complete assembly beforeyou startedaking it apart? Did you get the shift gate out of the way? That third bolt is a bugger huh.Last edited by iceracerdude; 09-20-2011, 04:38 PM.
I have the trans all the way down to the shift rods, forks, and gear clusters. When you say to remove the pins from the rods, do I need to remove all of them, or just the ones on the top two aluminum forks?
I did in fact clean the magnet off. The fluid was very dirty, a brownish color, and it was hard to even tell the magnet was a magnet at first. At first I was under the impression that the gear clusters needed to come apart, thank god that is not the case. I take it that the little 3/8ths pin is the one in my first picture? I still cant figure out where it came from.
Thank you again for the information!
Alright, if you look into those holes the shafts came out of in this picture, I can still see the ends of two of the three springs. Remove the bolts holding them in and tag which spring goes with which bolt and hole, The balls ride on the ends of these springs. The balls are all identical, (interchangable) the springs are all different sizes and must go back in their correct spots. These go back in last thing, yes even after the case bolts.Originally posted by jjk1224 View Post
Pick up some RTV gray, or ultra gray for the reassembly, as well as a torque wrench.
Ok, that was one of the things I told you about, those balls and the springs associated with them. You should have taken all of the bolts out first, the obvious ones around the trans case, but also the ones that hold those balls and springs in directly across from those shift shafts. There will be three of them total. You'll need to remove the shift gate completely. Very easy except for the one bolt, which having a gear wrench with a pivoting box head would help. Once you pull the gate out then see if the reverse gear will come out for you by removing the bolts on it's arm. It's that arm that works kind of like a see saw!? The shift shafts have drift pins going through the shift forks, you'll want to take pictures at this point so you can compare when reassembling so you can remember. which shafts and which forks go together in which holes.
Drive the drift pins out and be carefull, the forks are aluminum. You'll need to slide the shift rods out of the forks in order to remove the forks before you pull the gear clusters.
There's a little pin about 3/8 long at the bottom of those 3 shift shafts, watch for it.
Also, what's this talk about syncros? You aren't taking any syncros apart. They're on the gear clusters and there's no reason to remove them, you'll be pulling the entire gear cluster shaft straight up and out together leaving all of the gears where they are. Then you'll place them back into their coresponding spots again, then the forks, then the shafts down throught the forks, then the drift pins back into the forks. Unless you pulled that magnet out and cleaned it off already and put it back, that trans seem to be in pretty good shape! Next time don't let these guy's goad you into taking stuff apart till you get some guidance first, that way you won't cause any eareparable damage to anything.Last edited by iceracerdude; 09-19-2011, 05:05 PM.
This is the stuff that fell out yesterday. From what I understand that has already been posted, the bearings go into the holes with the springs, but where does the little pin go?
To begin removing the syncros and gears, do I have to remove the springs and bearings first? I have no clue where to even start taking things apart.
If you leave one axle in while you change-out the other side, DON'T turn the axle that is still in place while the other side is axleless.Originally posted by denguy View PostDon't ever turn the transmission while the axles are out, the side gears will stay in place unless you turn the trans while it is in a gear. Even if you leave one axle in while you pull the other one, the side gear without an axle in place will drop down if you turn the trans. Keep in neutral. There is a PVC pipe size that is a pretty close fit going into the side gears from each side.
