1990 Ford Festiva L Plus EFI Auto.
Alrighty.. been a while since I've been on here, I've been too busy to even think about my little guy sitting out on the front lawn (been working usually odd shifts like 8am-9pm, or something idiotic like that.
BUT. The tank Link gave me (thank you so much!) is finally on. When I took off the old tank, I found several 1-2mm holes, the lines (of the tank, that is, not the fuel lines) running from it were rusted off, and I honestly don't know how it kept the car going for so long.. Honestly took more work to get it on than expected, but I'm a complete novice with car repair..
Now there's no fuel leakage whatsoever (I put in about 3/4 gallon, turned the key so fuel pump would engage), and I can finally get around to figuring what's the problem.
So, question time:
...What in the heck do I do now? I put new plug wires on it, used battery, Link's tank. That's it so far. I know it DID run when we test drove it, and I'm wondering what could be a possible problem I can check?
The starter sounds good, it's turns over and over but won't start. I'm hoping it's something small.. after it's running I'm going to take it to a mechanic to give it a once-or-twice-over. All I need is the darn thing to start.
Any tips at all would be greatly appreciated, and please remember I'm a novice and might need a little/heckuva lot more explaining.
~Spike
).BUT. The tank Link gave me (thank you so much!) is finally on. When I took off the old tank, I found several 1-2mm holes, the lines (of the tank, that is, not the fuel lines) running from it were rusted off, and I honestly don't know how it kept the car going for so long.. Honestly took more work to get it on than expected, but I'm a complete novice with car repair..
So, question time:
~Spike
