Ok, so I've been having an issue with acceleration. Usually in 2nd and 3rd is when it happens, push the throttle down and it hesitates before it gets power back. I looked up in several posts here what might be causing that, seems one of the main points is the timing might be off.
I got the water pump pulley off, upper timing cover pulled, had the car jacked up to get to the lower pulleys. When I went to get a socket on the crankshaft nut, I found that it would go on there, but no room whatsoever to get a breaker bar or ratchet on there. I could get a box end on there, but couldn't get enough leverage to break it loose. I even tried going both ways on it, thinking it might be a lefty thread.
I know the timing can be checked without taking all that apart, but from the way the belt looks, it really needs to be replaced. I saw one person post about removing the engine mount and jacking it up on the back end, thus dropping the front of the engine down.
