My rear strut bottom mounting bolts seem frozen. I tried some "Blaster" but they still don't seem to move. Any ideas?
Frozen strut mounting boltw
Keep soaking with the p b blaster. The other option is heat, but that's kinda dangerous.Im not driving a Festiva because I'm poor. I drive a Festiva because i want to!
Dennis
93 GL In progress BP/hydro G
15 Mitsubishi Mirage daily
88 Dakota tow pig
if you find that after a week or so if "blasting" it, the bolt is still frozen (not uncommon), you can remove the strut with a 3' cut-off wheel and a large punch.
remove the offending wheel, then cut the bottom of the strut bushing loop as close to the vront of the BOTTOM of the support "loop" as you can and then again just above the rear of the support "loop" esentially cutting the bottom strut ring in half. remove the piece and then push down on the axle and remove the rest of the strut. the bushing and inner collar and frozen bolt are still on the axle. cut the head off the bolt from the outside of the "loop" and then carefuly cut between the collar and the main arm of the axle from below (may require several sizes of wheels, BUT, now you can rotate the bushing and cut a little at a time from the bottom. eventually you'll be able to pop the bushing out. once that's done, take your punch and wack off the welded nut inside the axle. replace with a lock nut and grade 8 bolt slathered in anti-sieze.Trees aren't kind to me...
are you soaking the threads that are hidden inside the beam too?
whatever you do, follow festyboy's post above.
do NOT cut the beam. any part of the beam. just the strut
it's pretty common that the bolt gets corroded inside the sleeve. it's such a pain. I have more than a lifetime supply of anti-seize in each bolt haha
I'd be curious to know if hitting some of the components in there with a mini sledge will break up some cohesion and loosen things up a tad. like with old screws and bolts sometimes...who knows
So are the meatl sleeve & rubber bushing available? I read that people are cutting them up to get at the bolt. Jus wondering cuz I know its in my future plans.....Some people like to read fiction,I prefer to read repair manuals. Weird I know-
^ they are part of the strutTrees aren't kind to me...
Thanks, makes sense-Originally posted by FestYboy View Post^ they are part of the strutSome people like to read fiction,I prefer to read repair manuals. Weird I know-
I used a 2 ft extension pipe and full body weight on a T-bar socket driver with an impact socket, pumping on the pipe until the nut broke free. Crack! is the noise the nut makes when it starts to turn. I also recommend using a wire brush to clean the threads in addition to the penetrating oil. Photos at http://ww.photobucket.com/festiva-frontwheel and start at photo #63.Last edited by WmWatt; 09-28-2011, 11:59 AM.Original owner of silver grey carburetted 1989 Festiva. 105k km as of June 2006. 140k km as of June 2021.
wow, nice work WmWatt, I only got through 1-2 pages of your album but looks great!!
