So, my white 1988 Festiva is giving me some bizarre electrical troubles. I recently dropped in a motor from my other blue '88, and when I turn the key to START, a handful of things have happened:
1. It shorts, and I lose all power to the system. I have to disconnect the main fuse/negative battery terminal to restore power.
1.5. It shorts, and I lose all power to the system. Disconnecting the fuses/battery does nothing. Leaving the battery out for awhile usually fixes this one..
2. It shorts, I lose power to ACC and ON, but the cooling fan spins when in ON. Leaving the battery out of the car for awhile will usually fixes this one as well..
3. It shorts, power is lost to the ON ignition setting, but power remains to the ACC; door buzzer still functions.
4. It shorts momentarily, but power remains to the ON setting of the ignition.
Both the chassis and engine were in working order before the swap. The only notable differences are transmission.. 4spd vs a 5. The starter is good, the fuses all show to be in working order, the battery connectors and terminals are solid, the battery is solid, all of the electrical connectors in the engine bay have been inspected and appear to be fine.. I don't know where to look or what to do. The only glaring issue I've discovered is that this tiny ignition box had a pair of broken contacts.
These were repaired, but the issues remain. The weirdest thing is that randomly the car tried to turn over. We had spark and everything, but shortly after it went back to shorting out. I thought that the fan relay might be out of whack, but upon replacement the issues pressed on. However, I did not discover the broken contacts until after trying both relays in the system.
I'd really like to get Steve running again :\ Any help or guidance will be greatly appreciated.
Ask me any questions at all if I missed anything..
I like the yellow ones. There's one that appears to be abandoned not too far from me that I really want to snag.. the body is in nicer shape than both of my Festys. Tabs on the car say 2004!
And I actually have the 1988 electrical book, but thanks!
