wmwatt or pgh5spd when you say you do it by the gravity method are you talking about the mc or the whole system? By doing it that way will the end result be the same as using the pump and hold the pedal method? I was under the impression that someone had to apply the brake to force the bubbles out. How much brake fluid would it take to do all 4 lines? I have two 500ml bottles of brake fluid on hand.(approx. one quart)
I'm just curious because I've never heard of the gravity method before and if I cannot find anyone to do the brake pumping that method would be a viable alternative.
