So Friday night the stud for my escort alternator snapped. I removed the braket and hooked up the eyelet on the back side of alternator. I kept blowing main fusible links while reconnecting the battery. So I threw the festivaalternator on... is the festiva alternator enough to power my car with a bp in it? Oris there a wayh I can get escort alternator hooked up with the stud broke?
alternator problem
I ran Festiva alternator on my BP for 50,000 miles without issue. The BP is rated for 65amp and the festiva is rated for 50amp. Which stud snapped? The one the eyelet is supposed to bolt to? And in what way did you "hook up the eyelet on the back side of the alternator"? I'm still not sure exactly what happened... or why you would remove the bracket? If you have that eyelet hooked directly to the body of the alt, thats why its blowing fuses. That eyelet goes directly to the battery + side through the links so if it touches anything grounded it will keep popping fuses. Maybe a pic of what broke?Last edited by htchbck; 10-03-2011, 09:59 AM.No festiva for me ATM...
Computers, fuel injectors, and ignition coils all require electricity.Originally posted by georgeb View PostIt shouldn't take any more amps for one motor as another because they run on gas.
Turn off your engine while driving at night but leave the car in gear. The headlights will get brighter because the alternator is still spinning and generating power, but there is less load with the engine computer and ignition system off.
The difference of 15A is only for accessories found on larger and/or fancier cars that the BPs came from. Accessories our cars do not have.~Austin
Red 88 L (Ocho)
