The car is an 89 lx.
It ran three years ago before the engine blew.
Installed rebuilded engine at sametime as I did the auto to man swap.
Brake and backup lights work. Netural safety switch has been wired together.
I have a white spark at the #4 plug. Car will not start on starting fluid.
There is no power going to the fuel pump or relay behind the back seat.
This is my second auto to man swap. Althrough the first was a 91 and this is a 89. On the 91 swap, there was a cable going from the shifter to the ing. switch so that the car could only be started in park. The 89 did not have this. So what prevents a 89 auto from starting in gear?
What else can I check to get power to the fuel pump?
When a car does not start because the saftey switches are not close. What is disabled? Fire or fuel?
What else could be wrong?
Has anyone else done a swap on a 89?
Thanks everyone for your help.
David Hodges
Memphis Tn
901/281/1458
David Hodges
Memphis Tn
901/281/1458
