Radiator fan stopped working
  • Radiator fan stopped working
    Hey guys,
    About a month ago I unplugged my fan after I parked it so it wouldn't drain my battery any(I was limping on a bad battery and would need jumps often).
    I plugged it back in and it hasn't worked since...
    Now if I idle too long after reaching operating temp. it'll start to overheat and coolant will start to bubble out of the overflow res.. Obviously I turned the car off as soon as this happened but I'm afraid to drive it anywhere out of fear of being stuck in congested traffic, causing it to overheat again.
    Any help would... well... Help! I can't figure it out and I'm starting to feel like I'm beating a dead horse
    (I've made sure the male and female connections were clear of debris etc. without resolve)
    Thanks guys,
    Chris
    Last edited by g00db0y; 10-04-2011, 12:39 AM. Reason: Former wording sounded like comical sexual inuendo
    Go ghostiva, go!
    '88 LX "tiny little ghost" White - 5 speed
    Oops
    Forgot to add that it's an 88 FF.
    Go ghostiva, go!
      is the fuse still good?
        Would the fuse blow just because I unplugged the power connector?
        Is the fuse for it under the hood or on the main fuse panel above your left knee?
        Go ghostiva, go!
          The fuse panel inside the car. It's a 20amp fuse labeled "Cooling Fan"
          BP, Aspire brakes, stock trans.
            Ground the wire to the fan switch with the key on. If the fan runs it's the fan sw. If it doesn't run, it's something else.
              Hey guys,
              Thanks guys,
              Chris
              If you werent carefull,you could have damaged the male/female connector wires.(if you pulled on the wires to disconect,instead of the plug itself)
              Also look at the "male" metal tabs of the connector. Are the tabs still there & in good shape?
                After adding this post I checked my '89 wiring manual. The above procedure is correct to check the fan sw but engine temp must be above 207 degrees F. The sw is normally closed as is the relay which is odd. The relay is energized by the METER fuse, so check that.
                  Why is it odd?
                    Originally posted by nitrofarm View Post
                    Why is it odd?
                    Maybe it's not odd at all, but when I think of a switch, I think of it as normally open. Same with relays. Don't know why they would have the relay pulling 99 percent of the time then being relaxed to turn the device on. Extra work for the alt.
                      There is a reason....
                        If the relay failed, it would fail into the normally closed position and turn on the fan as a fail-safe.
                        I believe if you unplug the fan switch, the fan should kick on. When the wire to the relay sees no ground, an open circuit, it kicks on the fan. Yes, the fan switch is normally closed to ground and opens when it reaches high temperatures.
                        -Zack
                          I was hoping he would figure it out himself
                            So if you unhooked the fan switch wire, the fan should turn on even if the engine is cold. Which means that the primary part of the relay could be bad also and the fan will run. Which just leaves the fan, fuse, fan relay secondary circuit, and connections.
                              I talked to a local mechanic and he said I confused the chip and need to either get it reset or create a direct circut with a manual on/off toggle on the dash. Could this be the case? I'm not sure where this fan switch is you mentioned.
                              Go ghostiva, go!
