The previous drivers side axle in the Aspire clicked on corners so I replaced it today. It's always pulled hard to the right on certain roads and when it pulls hard would make a wobble sound. The alignment is close enough it shouldn't pull that hard. I replaced the sway bar bushings today also. It has been hit on the passenger side front and the cross beam is bent (see below). The problem now is it sounds awful. I guess it's pulling on the new boot. I'm going to measure the axle tomorrow but I'm pretty sure it's the same. Anyone else have this problem?
I'm guessing the subframe is bent. Well the only positive thing is now I know that everything on Aspire is worth swapping to the Festiva if I have to. I bet the 97 gearing will be awesome in the Festiva.
![](http://i9.photobucket.com/albums/a58/ericsmith32/Aspire/IMG_0936.jpg)
