When the OP did the BP swap in my Festiva, he never hooked up the wire from the temp sending unit to whatever wire goes to the cluster gauge. I was wondering, if I hooked up a wire from the sending unit to the wire going into the cluster, will my temp gauge work?
Temp gauge not hooked up will this work?
It should..... isn't the stock temp sensor wire still intact? just re-use that wire instead of running a whole new one
Theres a cut wire on the sending unit at the thermostat housing but I don't know where the rest of the wire is. I'll do a hard target search today and hope to find it.Originally posted by Damkid View PostIt should..... isn't the stock temp sensor wire still intact? just re-use that wire instead of running a whole new oneSemper Fi til I die!
1993 Fescort GT 1.8 BP automatic Kia Rio front struts and cut springs Cut Front Festiva springs with Monroe Aspire struts in rear
