it revs way up when i start it and i can still make it go higher with the pedal but i can not get it to go any lower. i have backed the idle screw almost all the way out so i know thats not it. i had a broken servo that i replaced which i originally thought was the problem but it still does the same thing. the way it happened was i started it up in my driveway this morning and it started and everything just fine then i get a ways down the street and all of a sudden it just started to rev way too high. i was going a steady 40 in 4th without even touching the gas. im thinking it may be a vacuum malfunction somewhere but i dont even know where to start. any help will be greatly appreciated...for now its 11 mpg in the ol truck.
Revs to about 3/4 throttle on startup
look for vak leaks at the brake booster/lines and at the IAC lines.Trees aren't kind to me...
driver side of the intake manifold (blue plug).Trees aren't kind to me...
ok. i was figuring on a EFI car... if you have a carbie, you need to look at the base gasket first.Trees aren't kind to me...
Carb Butterflys closing all the way?Last edited by nitrofarm; 10-11-2011, 06:42 AM.Some people like to read fiction,I prefer to read repair manuals. Weird I know-
Try plugging in the block heater for an hour before starting. That reduces choke. Also as soon as the engine fires pump the gas pedal a few times to release the choke. Those things should tell you if it's the choke.Original owner of silver grey carburetted 1989 Festiva. 105k km as of June 2006. 140k km as of June 2021.
