..yeah, my e-brake light never turns off any more,even when its all the way down, any ideas
e-brake light not going off
Re: e-brake light not going off
Check the fluid.Originally posted by xanthinic12..yeah, my e-brake light never turns off any more,even when its all the way down, any ideas97 Ford Aspire 2dr 5 sp
92 Isuzu Impulse 1.8 5 sp 140HP, handling by Lotus, balls by Isuzu.
95 Mitsubishi Expo 2.4
http://img.photobucket.com/albums/v2...64/xsext2a.jpg
master cylinder
brakeOriginally posted by xanthinic12which fluid?97 Ford Aspire 2dr 5 sp
Also check the tension on the ebrake cable, you can adjust it by loosening the bolt on the top of the cable when you take off the cover... It may be soo tight that it is causing the light to stay on even when it's in the down (off) position... -KyleCosmic Blue 2008 Mazdaspeed 3 - Mostly Stock...
"BRAKE" light on continuously means no brake fluid
I had this happen ("BRAKE" instrument panel light on continuously) on one of my 88s, and it had nothing to do with the handbrake. It had a slow fluid leak and was down to almost nothing in the brake reservoir, i.e. imminent total brake failure. The light is on continuously and you think it's just a handbrake switch problem, check again!88L black, dailydriver
88LX silver a/c, dailydriver
4 88/89 disassembled
91L green
91GL aqua pwrsteer
92GL red a/c reardmg
1952 Cessna170B floatplane
