i have a 93 festiva { no ac }and i have to change the v velt on it 3 times this month because everytime i change it it last around 5 days with out squiking. then i tigth the belt and the squiking stops for a few more days.i have owend the car 6 months and really love the car but cant figuire where the problem is ..if you have any help plese let me know thanks..new to festivas
93 festiva changed belt 3 times this month please help..
You should probably check the pulleys for any kind of roughness or anything that may cause the belt to wear out. Also, how tight are you tighting it?89L build thread http://www.fordfestiva.com/forums/sh...ad.php?t=36422
My site: 20tessa.sytes.net
check all pulleys when the belt is off and make sure they are turning freely."FLTG4LIFE" @FINALLEVEL , "PBH"
also, check for an oil leak and check the crank pulley for runout.89 Festiva L Carby 4 Speed... RIP. Evicted and Scrapped. I HATE MY FAMILY
Facebook Me!
Originally posted by 91_festy_Gl View PostYou should probably check the pulleys for any kind of roughness or anything that may cause the belt to wear out. Also, how tight are you tighting it?Mipulga
Something ain't right. I have a hard time imagining how pulley alignment might become off but a mis-aligned belt would certainly be noisy and short-lived. Are you using the correct alternator and are the pulleys all of the same variety? Aspires for instance use serpentine belts instead of v belts and obviously the pulleys on the crank/waterpump/alternator are quite different. Good luck.
I haven't been able to find the dimensions of the drive belt on the Interent. The last one I put in was a Power Torque 15350 (SAE standard J636). The one I took off has "SP AUTO-FLEX-N FM-35.2" written on it. Not very useful.Original owner of silver grey carburetted 1989 Festiva. 105k km as of June 2006. 140k km as of June 2021.
Originally posted by WmWatt View PostI haven't been able to find the dimensions of the drive belt on the Interent. The last one I put in was a Power Torque 15350 (SAE standard J636). The one I took off has "SP AUTO-FLEX-N FM-35.2" written on it. Not very useful.
The #15350 was 35" long, designated by the 3rd and 4th digits.
The 35.2# in the second example designates allegedly 35.2" long.
Hope this helps.
