You can put a dead battery on your o2 sensor to ecu wire and check your plugs every once in a while to see if they are white. That works too. Even cheaper than 7 cents.
Performance chip
It is a scam. First off, It isn't even a CHIP! It is a 30 cent resistor installed to change the air flow signal, so the ECM will lean the fuel mixture.
When is everyone going to learn "Money back guarantee's" mean NOTHING!
Stay away from these other SCAMS: Pulstar Spark Plugs, Blue Lightening Spark Plugs, The Old "Magnetic on the fuel line", "Vortex', & Electric Turbocharger.
Originally posted by Festiva Time View PostIt is a scam. First off, It isn't even a CHIP! It is a 30 cent resistor installed to change the air flow signal, so the ECM will lean the fuel mixture.
Stay away from these other SCAMS: Pulstar Spark Plugs, Blue Lightening Spark Plugs, The Old "Magnetic on the fuel line", "Vortex', & Electric Turbocharger.1988 Chevy Sprint Turbo 997cc
Originally posted by nitrofarm View PostNo offense taken.Just wondering if anyone would own up to buying one of these.
Originally posted by avitsef View PostI will own up to buying one ... im a sucker for such scams that promise - figure if i keep trying eventually i will get a winner - but this was a wiener , at least for me . I did get the en-valve also off ebay , that replaces the pcv valve and it does everything as advertised .Some people like to read fiction,I prefer to read repair manuals. Weird I know-
I recently installed one of these in my 1952 Cessna with 1960s-technology carb'd engine. I now get so much power that I can take off crosswise on big-airport 200'-wide runways, and cruise at 35,000' with the "heavy iron" kerosene burners. The extra power I get even allows me to carry a heavy oxygen tank and artic survival gear to survive at that altitude.
The only problem I have is seeing the ground from seven miles up since I still don't have GPS. Doing a "hang a right at the third fiord" is a big tough to do from that distance.Last edited by AlaskaFestivaGuy; 10-23-2011, 10:37 AM.88L black, dailydriver
88LX silver a/c, dailydriver
4 88/89 disassembled
91L green
91GL aqua pwrsteer
92GL red a/c reardmg
1952 Cessna170B floatplane
Originally posted by nitrofarm View PostWOW,thanks for your honesty. A lot of people wouldnt have admitted this. I'm truely sorry this KNUCKLE HEAD got your hard earned Dough. Props to you Dude,seriously.:wav:
Originally posted by AlaskaFestivaGuy View PostI recently installed one of these in my 1952 Cessna with 1960s-technology carb'd engine. I now get so much power that I can take off crosswise on big-airport 200'-wide runways, and cruise at 35,000' with the "heavy iron" kerosene burners. The extra power I get even allows me to carry a heavy oxygen tank and artic survival gear to survive at that altitude.
The only problem I have is seeing the ground from seven miles up since I still don't have GPS. Doing a "hang a right at the third fiord" is a big tough to do from that distance.Some people like to read fiction,I prefer to read repair manuals. Weird I know-
