You read my mind.......lol lol
i will mail $20 to the person who helps me fix my festiva
passenger side, behind headlight, on the air box (where your air filter goes).Trees aren't kind to me...
ok im the original poster to this whole problem...and im at my house trying to communicate with my b/f...would someone be willing to give me their number and let him call you to talk about his festiva???? im just the middle girl trying to help my b/f..lol he said he thinks he replaced the vfa...
a location might help you more than you know... we have members EVERYWHERE!!!
muuuahahahahaaha
lolTrees aren't kind to me...
We have a number of prominent member in MO.
As said above, a city in your profile can pay dividends!
Up to you!
I promise no salesperson associated with FF.com will call on you!'93 Blue 5spd 230K(down for clutch and overall maintanence)
Yep, that was me, on mine it was the white wire going to the VAF was broken/burnt. Even switched VAFs with one out of one of my other festivas that KNEW was good. Of course that didn't fix it because the problem wasn't the VAF itself but the wiring going into the VAF. I'm guessing that unplugging it makes the computer go into some kinda of default mode (on my car I was making it go away for a few minutes at a time by turning the key off then back on), but it still comes back. Your problem sounds very very similar to mine. Unplug it and check for any corrosion, broken wires, anything that could cause a bad connection in there. Could even be that one of the contacts in the plug is pushed back into the plastic on the connector, so when you're looking at the plug make sure all the little metal contacts in it are all even with each other. If you're unsure about any of it just take some pics and post them up, we'll get it sorted out for ya!Originally posted by Pu241 View Post2) Check the VAF connector, Festivas do not have MAF's, for burnt or corroded connectors.
If found, clean them up.
I believe a member here found a burnt and bent connector which caused running issues but not quite this mod of failure.No festiva for me ATM...
Wow, you checked on every member in MO, and your 2 hrs from them all?Originally posted by nabradley6 View Postjust looked and everyone is at least 2 hrs away!
I'm impressed.
Those I know personally and the geography of MO would put you in very remote sections of MO.'93 Blue 5spd 230K(down for clutch and overall maintanence)
Do you still own the hulk?Originally posted by shadetree View PostChange signature ? Why ?
