Hey everyone i just picked up a 93 Festiva GL Automatic with 224k. I am going to list problems it had/has and maybe you guys can give me tips on what the problem could be. I work on Kia's and im not familiar with the Festiva's yet.
Problems
1. Nothing on the gauge cluster worked
2. Automatic seat beats didnt work
3. Very noisey when driving down the street and has a very bad shake in the steering wheel
4. Bellows are missing off the steering rack on both sides
5. Exhaust leak (leaking from the down pipe right below where the flange is that bolts to the exhaust manifold. Also leaking from the gasket where the two flanges meet.
6. Floor is rusted through on the driver and passenger floor boards about 4 inch rust holes
7. Low beam headlights dont work (high beams do work)
8. Rear hatch wouldnt open
9. Left rear drum is stuck on the shoes, tried pulling it off and it wouldnt come off (I think i may have to force it off and replace the brake shoe hardware)
10. Trans fluid leaking
11. Valve Cover leaking
I fixed the gauge and seat belt issue the meter fuse was not in the fuse box. That made the fuel gauge start working as well as the seat belts. The coolant temp sensor prong was broke off (replaced the coolant temp sensor and now the temp gauge works), replaced speedo cable with a cable from an aspire and now the speedo works. I got a rear hatch latch and striker from the junkyard and got the hatch opened and replaced latch and striker so hatch works now. The trans was leaking and i thought it was from the drain plug because the drain plug did not have a crush ring install. I installed a crush ring and checked it. It seems to just be barely leaking now and seems to be coming from where the trans case would seperate. Any ideas on any of the other things i have listed? Common problems? Whats the typical fix? Sorry for the long post
Problems
