So i rebuilt my 5spd transmission. IN the process a shim escaped and left me needing one. I put everything back together and had the play in the input shaft measured. The transmission shop, of which I have never worked with before told me it had .00010 play in the shaft and that was fine because you want there to be a little play so as to ensure the bearings aren't preloaded. They also said to maybe get rid of a little of the slop is to run 90W oil.
Does this sound correct? 90W is a lot heavier and .0001 inches of slop is more than my friend mechanics have been telling me.
Help!
Help!
