Hey guys I haven't had a chance to pick up a manual yet. I need to know the torque spec for the axle nut on the back wheels. Thanks for any info
Torque spec for rear wheel axle nut?
NTRCOOL
1993 Ford Festiva GL
1990 ASC/McLaren Turbo Grand Prix x2
1989 ASC/McLaren Turbo Grand Prix
1990 Cadillac Fleet-wood Brougham
1987 Buick LeSabere T-Type
1980 Oldsmobile Ninety Eight Regency coupe
1977 Chevrolet Caprice Classic Aeroback coupeTags: None
there isn't a spec for that nut, what you so is put everything together and keep spinning the drum and tightening the nut until the drum takes some effort to spin, then back it off 1/8-1/4 turn (till the drum frees up but doesn't have play) and stake it down there.Trees aren't kind to me...
I put the Haynes instructions at www.photobucket.com/Festiva-backwheel
After you stake it down you can check for heat or play next time you drive it. When checking for play do not apply the parking brake (cable) as it will make a noise like the wheel is loose.Last edited by WmWatt; 11-27-2011, 10:41 AM.Original owner of silver grey carburetted 1989 Festiva. 105k km as of June 2006. 140k km as of June 2021.
All buttoned up thanks for the advice.NTRCOOL
The main culprit was the fact the previous owner didn't believe in cotter pins. The bearing was un damaged in the process.NTRCOOL
