The ignition module inside the distributor sends the tach signal, right?
I have this issue while driving that the engine will cut out, not a random misfire but actually shut right off, and the tach starts jumping around.
My best guess so far is that it's the wires between the distributor and ECU, but it also seems to be affected moreso by application of the brake pedal.
At times, this happens until the engine will not start, but it still had spark the whole time. When the wires had been shaken around enough, it finally started and ran fine for awhile, but has started this issue again.
