I cover the rad but I also block the center air vents from under the bezel. Seems no matter what you do there is always cool air coming in there.
Do you block the radiator in winter?
You know, I also wonder about the valve that opens and closes the coolant flow into the core? If every thing else is fine and this isn't working, you still wont get heat. Anyone ever find this valve to have failed,become disconnected from the slide controls, or maybe clogged?'93 Blue 5spd 230K(down for clutch and overall maintanence)
Originally posted by navdoc101 View PostI just don't understand any of this! When it gets cooold here my heat is fine. ;}
Keep driving till you find the land covered in white stuff locally known as snow.
Then lets see if your "heat is fine"!:p'93 Blue 5spd 230K(down for clutch and overall maintanence)
Well, in my other post about a rad cap, I'm wondering if when my car got about halfway up the gauge Saturday with the rad blocked if I cracked the radiator. I'm getting no pressure when "hot" but the water level isn't dropping either. I'm renting a pressure tester Wednesday to check my daughters Exploder cooling system, I'll check the Festy too.1963 Fairlane - future NSS drag car
Originally posted by Pu241 View PostJust fill your tank and driver north my friend!
I have an 88LX that never gets to temp. I never looked into it but did run with cardboard blocking most of the rad. at least one winter. It made a fair difference. Of course, I forgot it was there in the spring until I wondered why the gauge was climbing...DOH! My 89L works great, gets heat in a couple miles. I guess I have a car for summer and a car for winter...
Originally posted by Larry Hampton View PostWell, in my other post about a rad cap, I'm wondering if when my car got about halfway up the gauge Saturday with the rad blocked if I cracked the radiator. I'm getting no pressure when "hot" but the water level isn't dropping either. I'm renting a pressure tester Wednesday to check my daughters Exploder cooling system, I'll check the Festy too.
I put some worm drive clamps for now, I'll replace the hoses probably this weekend.1963 Fairlane - future NSS drag car
Originally posted by Top Tier Mafia View Postmine over heats, I poured water into the radiator and it is still in there just boiling, coolant boils too anyone know how to fix my over heating problem
For that little bent hose, take the old one to a McParts and compare it to what they have. You will probably have to buy something longer with the proper bend, and just cut to fit.
Oh, and welcome to the Forum BTW.Last edited by TominMO; 07-31-2015, 02:10 AM.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
I have a sheet of acrylic blocking the entire front during the winter. Have a 4inch wide separate piece on a hinge in front of the rad so i can flip it down when it gets warm, up when it gets cold. But my rad is beat so i have to take it all out for summer.
The MOST IMPORTANT thing is that you dont put cardboard or anything else directly in front of or contacting the radiater. You need some space in front of it so that if the fans need to turn on it can still move air.
I have replaced the coolant, rad cap, water pump, thermostat, and heater core on my festiva and still no heat when it gets cold. Lots of heat when its hot out, but not when its cold...
