My radio wiring was hacked badly and the aftermarket radio that was installed didnt work. I bought a factory radio and a Metra wire harness to be able to re-install the factory radio. My question is...on the power plug which wires go where in the plug ? the Metra plug has Red: 12 volt power, Orange: illumination, and Blue: power antenna. Blue is at the top and Red/Oragne at the bottom of the plug. Also in the Metra harnes is a yellow wire marked 12 volt memory. Would the yellow go to the single connection in the radio ?
I have located both the constant power and Acc hot wires in the harness and there seems to be an extra Green/red stripe in the harness that I dont know what it is supposed to connect to. Any help or photos whould be greatly appreciated.
1989 L Carby 4 speed
