Electric fan issues
  • Electric fan issues
    I went on a 120 mile trip this past weekend ,all was fine until I was almost home ,as I got close to home ,getting caught light after light ,the temp gauge started rising ,and I thought not now , I could only see ot being a head gasket .
    But when i finally got out in the open again it came down ?
    So when I pulled into the drive the gauge was up more than normal ,and the fan was not running ? I had the hood open ,I wiggled all the wires still no run ,while the car was still running.
    So I shut the car off and cycled the ignition switch ,and the fan came on, and continued to run as I started it , all has been well since .
    Is this a sign of a defective ign.switch
    HD2500 Duramax Chevy
    Z28 LS1 power 500 +
    Probably the relay. Mine does that on occasion.. but it's the opposite. The fan will run and won't allow the car to start. Cycle the igniton a few times and it goes away. The wipers have a tendency to do it also.
    91 rusty Festiva 260k
      sign of a defective driver?
      i had that happen to me once, i never found out why it did that, and hasn't happened since
        Also was your wife with you?
          no but a friend was on the whole trip , It was happening thru town on my way to drop him off . :lol:
          But I only cycled the key once ,and the fan came right on .
          Like the switch had a bad contact ? only time will tell.
          Z28 LS1 power 500 +
