o2 problem
  • o2 problem
    im having a very hard time removing the downstream o2 sensor on my 97 aspire i failed emission due to it not workin. I then thought maybe if i clean it up it would work well this is a good idea i cant get the thing to budge from the pipe.. are they reverse thread or just rreeeeaaallllyyy on there. what the easiest way to remove this thing with a lack in space...?
    Frankie
    http://www.facebook.com/#!/profile.p...00000110128487
      they're REALLY on there! and threre is no cleaning them... just replace it.
        If it's not an electrical issue with the o2 you might try a seafoam treatment, I honestly don't know if it will clean the o2 sensor, but it will clean the engine and alll the components, egr valve and stuff..
        It advertises it will help a car pass emissions tests, worst case senario you spend 10 bucks and have a motor that rev's like it's had a fresh ring job.
        2008 Kia Rio- new beater
        1993 Festiva- Fiona, DD
        1997 Aspire- Babyspire, DD
        1994 Aspire - Project Kiazord
        1994 Aspire- Crustyspire, RIP
          Unplug the wire & slide a 6pt box wrench over the sensor.If you cant get it still.Do the two wrench's in series trick.You know, where you put the box end inside the open end of another wrench.... That'll be way more leverage than you need. Lay on your back,get comfortable.Then pull really hard with steady pressure.Just dont hit your self in the face when it breaks loose.
          PS. you cant remove it with an open end wrench.always use a box.
            thanks everyone for the help..i just bought a new one off partstrain for $34 so i should be ok when it gets here
            Frankie
              Start soaking it now and everyday until it gets here. Use something better than WD like ZEP 45 or JB 80 , even PB blaster will eventually get through.
                ^ yes!!
                  If you use anti-seize thread compound on the sensor during the install make darn sure you don't get any on the sensor tip. Same goes for spark plugs.
                  Intense heat does amazing things to help loosen seized parts. If worse comes to worse firmly clamp a big pair of Vice-Grips on to the sensor and then smack them with a big hammer.
