My speedometor has quit working. I assume it's either a cable broke or a plastic gear wore out?Anybody bought either, or had any trouble with speedometor? I assume it's not too hard a job to fix?Thanks for any tips or help in advance.
speedometor help
even easier, just pull the cable from the sheath and see if it's still in one piece (super easy to get back in if it is)Trees aren't kind to me...
Originally posted by Movin View Post1993 Ford Festiva (automatic) First car :) No nickname yet :(
http://www.revzilla.com/product/motion-pro-speedo-cable-kit?utm_source=Google&utm_campaign=Tool&utm_medium =base&utm_keyword=motion-pro-speedo-cable-kit&adtype=pla&kw={keyword}&gclid=CPfMsYPd3K4CFWsa QgodRCnZWQ#activate_zoom
This costs twice as much, $14 but has several ends to choose from..Do you have a pic
of the connector? Also I used copy link above but the company, revzilla.com can be
searched.Reflex paint by Langeman...Lifted...Tow Rig
you can use a Protege dx manual trans cable... or a complete aspire cable as well.Trees aren't kind to me...
Thanks for the help
Thanks for the help on the cable.I ended up buying a used one from the local scrap yard. It works good but I would have rather put a new cable in. Thanks again for sharing all the information.Everythang is chickin' but the bill, stur it up real good and it's chickin' still...
Unless you're preparing/planning for an heirloom, used parts are worthwhile especially when the job of putting them in is not monumental (ie speedo cable). A car usually wears out long before the cable. Hope you lubed this one carefully and checked for kinks or other suspicious places of friction.
People here have been discovering that early Kia Rio parts are sometimes compatible with Festys and it may be that speedo cables and sheaths are another one of those parts.
Glad you found something that works!
