I've been trying to figure out which wire to tap into to make my temp gauge work but am not 100 percent sure. I tried the one wire on the thermostat housing, wrong one. Then the one next to that with a blade type connector, totally wrong, it pegged the gauge when hooked up. There is one more connector right next to the thermo housing with a green connector and two wires coming off of it. One is black and the other is red with green stripe. I'm hoping this red/green one is the right wire for the gauge.
Is green connector next to Thermo housing for gauge
The 93 festiva will have a yellow wire with white stripe leaving the cluster. If you got the engine and harness from a 91 protege it will have a black wire with a orange stripe. You should be able to make the gauge read hot with a 10 ohm resistor hooked between the harness connector and ground. 73 ohm should read cold. The sensor you are hooking it to should read in that neighborhood depending on water temp. That would be from sensor plug in to the ground (nut part) of sensor.Reflex paint by Langeman...Lifted...Tow Rig
The little sensor in the front of the head near the thermostat housing provides a variable ground for the temp gage circuit I think. If you take the wire off it and touch it to ground the gage will climb to the top, at least it did on mine. I got a new sendor at Advance Auto parts for $10.99. Part # WT608P. Got my gage working again.
I hooked up the gauge wire to this wire and it went to the top of the gauge. So is it the flat blade looking thing? I will take pics and see if its what you're talking about.Originally posted by denguy View PostThe little sensor in the front of the head near the thermostat housing provides a variable ground for the temp gage circuit I think. If you take the wire off it and touch it to ground the gage will climb to the top, at least it did on mine. I got a new sendor at Advance Auto parts for $10.99. Part # WT608P. Got my gage working again.
Thanks Movin for the info, if Denguys part doesn't work I may try the resistor thing.Semper Fi til I die!
1993 Fescort GT 1.8 BP automatic Kia Rio front struts and cut springs Cut Front Festiva springs with Monroe Aspire struts in rear
