So I'm in the middle of a B6-DE swap, got the motor and trans yanked out, and see that there's nothing left of my cv's, controls arms, and rack & pinion bellows... Literally, nothing. I got all new stuff, but the only replacements for the bellows I can find (RockAuto, API, Advanced Auto Parts, BapGeon) are for Festivas with power steering, and I'm no expert, but there's definitely no PS pump on the car, and I've never seen a stock Festiva with PS... So what gives? Can I use these bellows just the same, or do I need to go ahead and drop $300 on a whole new rack & pinion?
Rack & Pinion
I just use the cheap $6 shock boots from Autozone or wherever. Couple of Zip ties also
This website is for sale! festivamotorsport.com is your first and best source for all of the information you’re looking for. From general topics to more of what you would expect to find here, festivamotorsport.com has it all. We hope you find what you are searching for!
Has the real parts on sale for $15 also...Last edited by mikeand; 12-27-2011, 05:04 AM.1991 Smoketiva - 306k
1997 Jeep Cherokee - 4.6L Stroker
2004 Sebring
Run the rack back and forth and clean it up real good, use a little boat trailer wheel bearing grease or similar then pretty it up with the new boots.
The cv's, same drill but use cv grease , it should be with the boot kit. Force it
through the cv and use the whole tube or bag in the joint, packing both sides.
I would just get new control arms and tierod ends, they are cheap.Reflex paint by Langeman...Lifted...Tow Rig
festys rarely came with P/S, but the boots are the same for all years/models.Trees aren't kind to me...
I recently installed a pair of these: http://www.ebay.com/itm/Set-2-Manual...-/150720055045 I was a tad skeptical since I haven't heard anyone mention that any Honda boots work, but they're very nice. Much better than what came from the factory. Rubbery, not plastic-y
+1 i got these and they fit awesome mine came with some metal clamp but i used a zip tie insteadOriginally posted by Pgh5spd View PostI recently installed a pair of these: http://www.ebay.com/itm/Set-2-Manual...-/150720055045 I was a tad skeptical since I haven't heard anyone mention that any Honda boots work, but they're very nice. Much better than what came from the factory. Rubbery, not plastic-y
I buy mine from RockAuto.com, they are listed for Festys and Aspires. $15 IIRC.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
In what way? I think the plastic ones will last a lot longer.Originally posted by Jim Rockford View PostI too just purchased the ebay ones listed above, rubber is better than plastic anyday.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
The funny thing is the "rubber"ones aren't even rubber they are likely TPO (ThermoPlastic Olefins) and only slightly different in composition from the "plastic" ones which are likely PE (Polyethylene) or an alloy of PE/PP(Polypropylene). They are all plastics.Originally posted by Jim Rockford View PostMy car only has 127k on it and the stockers are torn to shreds... plastic gets hard and then breaks, I've been working on cars for 20+ years and I think I'm seen enough of each to make my decision
FYI if they were rubber they would be susceptible to heat, UV, and Ozone degradation and likely fail faster than the "plastic"ones.
It's like the guy I asked in the Lowe's what kind of plastic was used in the "instrument" cluster of the riding lawn mower. He replied "hard" plastic!
