Rack & Pinion
  • Rack & Pinion
    So I'm in the middle of a B6-DE swap, got the motor and trans yanked out, and see that there's nothing left of my cv's, controls arms, and rack & pinion bellows... Literally, nothing. I got all new stuff, but the only replacements for the bellows I can find (RockAuto, API, Advanced Auto Parts, BapGeon) are for Festivas with power steering, and I'm no expert, but there's definitely no PS pump on the car, and I've never seen a stock Festiva with PS... So what gives? Can I use these bellows just the same, or do I need to go ahead and drop $300 on a whole new rack & pinion?
    From under the car, it comes out:
    żlləɥ əɥʇ ʇɐɥʍ
    I just use the cheap $6 shock boots from Autozone or wherever. Couple of Zip ties also
    Has the real parts on sale for $15 also...
    1991 Smoketiva - 306k
    1997 Jeep Cherokee - 4.6L Stroker
    2004 Sebring
      Run the rack back and forth and clean it up real good, use a little boat trailer wheel bearing grease or similar then pretty it up with the new boots.
      The cv's, same drill but use cv grease , it should be with the boot kit. Force it
      through the cv and use the whole tube or bag in the joint, packing both sides.
      I would just get new control arms and tierod ends, they are cheap.
        festys rarely came with P/S, but the boots are the same for all years/models.
          I recently installed a pair of these: http://www.ebay.com/itm/Set-2-Manual...-/150720055045 I was a tad skeptical since I haven't heard anyone mention that any Honda boots work, but they're very nice. Much better than what came from the factory. Rubbery, not plastic-y
            +1 i got these and they fit awesome mine came with some metal clamp but i used a zip tie instead
            06 Jeep Cherokee Overland
            95 Aspire (sold)
              I buy mine from RockAuto.com, they are listed for Festys and Aspires. $15 IIRC.
                I too just purchased the ebay ones listed above, rubber is better than plastic anyday.
                  In what way? I think the plastic ones will last a lot longer.
                    My car only has 127k on it and the stockers are torn to shreds... plastic gets hard and then breaks, I've been working on cars for 20+ years and I think I'm seen enough of each to make my decision
                      The funny thing is the "rubber"ones aren't even rubber they are likely TPO (ThermoPlastic Olefins) and only slightly different in composition from the "plastic" ones which are likely PE (Polyethylene) or an alloy of PE/PP(Polypropylene). They are all plastics.
                      FYI if they were rubber they would be susceptible to heat, UV, and Ozone degradation and likely fail faster than the "plastic"ones.
                      It's like the guy I asked in the Lowe's what kind of plastic was used in the "instrument" cluster of the riding lawn mower. He replied "hard" plastic!
                        FMS
                        Finally got hold of someone at Festiva Motor Sports, ordered a bunch of stuff, including the $15 boots, and I'm happy with them - perfect fit! Just wish they were green...
                        żlləɥ əɥʇ ʇɐɥʍ
