Found out I was testing wrong wire, fuel pump is getting a consistent 11.6v.
I put the stock b6t injectors back in and now it will barely idle, reads over 17.0 on the wideband and I can't even touch the throttle or it will die. Having trouble getting a new fuel pressure tester cuz my old one broke. But im running in circles now and have no clue what to do next.
Does an aftermarket fuel pressure regulator sound necessary? I replaced mine with an oem one
the wastegate rod was positioned funky and was holding it wide open. I successfully hit 16 psi for my b6t swap's first time
