good day!
my engine stalls @ 8 degrees BTDC...so, im in 10-11 degrees for now but im not satisfied...when your running any in the 1st to fifth gear, when you decelerate in about 20 kph the engine has no engine brake ..it's like its going to die or engine will stop.so, when i decelerate when im in 20 kph i will step on the clutch so that the engine will not die.. .how was that?vacuum leak?this was happen when i set the ignition timing to 10-14 degrees BTDC..but before it is set to more retard something like that..
