Originally posted by 2xclutchin
Engine Wont Start
Then as far as I know you have a good working Festiva(other than the tranny leak you posted about)! I am 99.8% certain it does that every time.Originally posted by JOERIDE View Postyes thats what i meanMike Holmgren
Thief Rvr Fls, MN
1989 Festiva L, carb. 4 spd.
"If at first you don't succeede, get a bigger hammer. If it breaks it needed to be replaced anyway."
I disconnected the battery the o2 sensor, VAF connection, and let her sit for a couple hours, got off work connected everything back up and she started right up drove her back home with no problems. Any ideas what this could be? i,m getting very frustrated.
So it wouldn't start as in it spun over but wouldn't pop off, or just clicked once you turned the key and that was all she wrote?
Thanks, MikeMike Holmgren
Thief Rvr Fls, MN
Try the "wire wiggle".
Try to get it to DIE while its running. Wiggle the VAF harness plug while its running & see you can get it to hic-up. Also try wiggling the plug for your Ign module.But from you past posts.It sounds like the VAF or VAF plug is bad.
TRY the wire wiggle Bro,its helped me many times with intermittant woes.GOOD LUCKSome people like to read fiction,I prefer to read repair manuals. Weird I know-
Next time it wont start check for spark
If it does it again, verify its getting spark.And verify your fuel pump relay is clicking on & off with key switch cyclesOriginally posted by JOERIDE View Postit just spun but wouldn't pop off, i don't understand why it is so intermittent. I just took my dog for a drive started right up no problem, shut it down got some beer and started right up and drove home.
Easy way to verify spark on the roadside.Have car in neutral with ebarke on.
Have key in RUN
Pull coil wire off Dizzy & set it on the eng block
Jump starter relay with a test lead so she cranks.
Look for spark
My guess is you'll have good spark.
Then you know its fuel issue.YOU HAVE TO NARROW THIS DOWN.
MOST IMPORTANT,check ground for fuel sending unit. Its the one coming off the fuel inertia switch.
MOST IMPORTANT,check Gounod for VAF. Its the heavy one on the front corner of the eng block.In front of the starter. A loose ground will cause your symptoms for sure.
You can fix this but keep your frustration in check. If this was my problem,I would def learn where my fuel pump relay is. And I would pull it out & bench test it with some light bulbs & a battery. I would cycle that thing till the cows came home. But thats just me,down on the farm. Now go and kick that Festy's butt. Its got a new owner & its trying to have its way with you. Dig your spurs in. And show her who's the new Daddy!Some people like to read fiction,I prefer to read repair manuals. Weird I know-
BEER GOOOOOOOD. Is it a STOUT or some whimpy miller lite?Originally posted by JOERIDE View Postthanks for all ya'lls help I will have to dig my spurs in her tomorrow, I'm gonna sit on the couch and drink some beer, and play some XBOX. Its been a long week. thanks again guys ill keep ya'll updated.
I love Dark Beers in the winter. Been enjoying some local New Glaurius brews as of late.Some people like to read fiction,I prefer to read repair manuals. Weird I know-
I just drink Budweiser pounders, never really been into dark brew that much although i don't discriminate if its beer ill drink it.Originally posted by nitrofarm View PostBEER GOOOOOOOD. Is it a STOUT or some whimpy miller lite?
Hit the pivot point with some PB Blaster to break it loose!Originally posted by JOERIDE View PostSo I think I may have figured out the problem, I started her up this morning drove to work just fine got off work no start. I had my friend mess with the little flap within the VAF and she started just fine. Does that mean the VAF is broken?
Corrosion and/or crude are probably binding it.
Spray and push it in and release it a few dozen times.
It is spring loaded so should return on its own.
If the door doesn't move when you crank it, the pump does not continue to pump fuel, so I think you found your problem!'93 Blue 5spd 230K(down for clutch and overall maintanence)
