Fan stays on when car is off
  • Fan stays on when car is off
    Hi Guys, My Radiator fan stays on when I shut my car off, I think it is related to the heater system, because, it shuts off if I turn off my heater. My car died once already, because I didn't figure out that something was wrong till I went out and tried to start my car. I don't think it's a huge problem, because I can just shut it off when I turn off the car, but it is a hassle, anyone ever hear of this and/or can this be a larger problem than I am making it? Thanks
    89' Maroon and black Festiva LX with a sunroof. :alien:
    The fan circuit stays on when there is an open circuit between the switch (front of engine) and fan relay. Check METER fuse. Also fan comes on with a/c. Make sure a/c is not on. Maybe that is why heater blower turns it off.
      ^ good thought there!!!
      1991 blue L, 5 speed.
      1988 red L-plus-all stock.
        Check grounds. Could be a faulty sensor. I've seen the sensor become loose and cause the fan to stay on.
        1989 Ford Mustang GT 5.slow
        1996 Ford F-150
          check that ignition power is getting switched off by the ignition
          switch. The relay is turned on when you turn the car off, the key
          then turns power off to the fan..
            LOL. I'm glad to see this question posted because I've got the same problem. I just unplugged the fan and did without.
              I got a buddy I can send back there, he can talk enough air to keep
              your car cool,
                Be ready to plug it back in if you get stuck in traffic. You can also run your heater blower wide open, weather permitting.
