I just aquired a 60k mile '91 festiva! I've gotten all the bugs out except, when I turn the headlight switch to the first position the dash lights come on as they should, but when I turn it to the second position my headlights come on but the dash lights go off- what gives here? Thanks!
dash lights work in first position then cut out when lights on..
That's weird, do the running lights stay on with the headlights?2008 Kia Rio- new beater
1993 Festiva- Fiona, DD
1997 Aspire- Babyspire, DD
1994 Aspire - Project Kiazord
1994 Aspire- Crustyspire, RIP
White festiva..
I didn't get the white one, this was parked at a neighbors for two years and I kept driving by it on my way to work (in my 15mpg ford f250 7.3 diesel). I did what any good picker would do, I knocked on the door, worked out deal and hauled it out of there. It needed new front tires, a rear window and drivers window, and an oil change. I will drive it today to work for the first time. Tommorow I'm getting all the componants to install A/C from the junkyard where I found a the window doner festiva.
Try spraying WD-40 or eletrical contact cleaner into the switch.
I used WD-40 on my ignition switch. Have never tried contact cleaner.Original owner of silver grey carburetted 1989 Festiva. 105k km as of June 2006. 140k km as of June 2021.
I have a wiper/turn signal/clockspring column assembly from my aspire laying around if you need one, I'd let it go cheap if you need it, just pm me. You'd have to splice the wires into your socket but they're not very different.2008 Kia Rio- new beater
Light Issue fixed!
Well, I got a new switch at the junkyard, I guest its the multifunction switch behind the steering wheel, put it on everthing works great. I suspect that 90% of all light problems probobly have to do with this switch. Easy repair..
Good Job !
You scored Bro.Around here they dont have to many Festy's in JY's.Originally posted by atomices View PostWell, I got a new switch at the junkyard, I guest its the multifunction switch behind the steering wheel, put it on everthing works great. I suspect that 90% of all light problems probobly have to do with this switch. Easy repair..Some people like to read fiction,I prefer to read repair manuals. Weird I know-
