ok will try that.......just about ready to donate this ol girl to the scrape pile...
93 festy still not running right please help
NNNOOOOO!!! don't do that. where are you located, there may be a member willing to give it a good home if you decide to let her go.Trees aren't kind to me...
Half !? The computer did a lot more than that, time yourselfOriginally posted by georgeb View PostCan't believe you haven't retrieved the codes. Your computer has done half the work for you.
on one of the dinosaur fuel injection systems that have no
self diagnostics , heck you can pull codes on one of these
quicker than the Snap-on modis can turn on!
^ they can't pull codes on anything older than 96, so don't waste your time. besides, i've never met any of those fools who actually KNEW anything beside what the screen in ftont of them said.Trees aren't kind to me...
Awe, give them some credit, they seem pretty good about figuring out theOriginally posted by FestYboy View Post^ they can't pull codes on anything older than 96, so don't waste your time. besides, i've never met any of those fools who actually KNEW anything beside what the screen in ftont of them said.
closing time and break time
What did the light flash?
If you can't figure that out give us a video
of the light flashing.Last edited by Movin; 02-07-2012, 11:01 AM.Reflex paint by Langeman...Lifted...Tow Rig
Sheesh, code 17 would come up, george I'm the one not good withOriginally posted by georgeb View PostNever was good with fractions.
fractions.
I think Festyboy might be on this one the way it
acts, wiggling the VAF connector didn't help I assume but the VAF
door could be sticky..clean that area up good and make sure the
door is smooth to operate.
The TPS in this system is an old style and not likely to cause this
problem, however if it did turn the idle switch on it might buck
and cough a bit, you can unplug it, ignore the check engine light
and test drive to see if that symptom goes away. Additionally I
think it has its own code, not the generic "17".
Bad computer grounds on the engine can cause this.
A bad MAP sensor, goobered MAP sensor hose or carboned over MAP
sensor port can all cause this.
ANY bad ground to the o2 or anything that can effect o2 sensor voltage
can cause this. Even spark plug wires routed parallel to the o2 sensor
wire can trigger this code and cause the engine to cough.
Check all that, I have a hunch that the VAF is most likely where you
will find it like FestYboy says. report back!!
