car dieing
  • car dieing
    I have a 90 L plus that I just finished rebuilding after hitting a deer going 70mph. Ran good but now it dies when you touch the pedel. Car starts and idles fine but you can only barely touch the gas or it dies. Did tune up plugs wires thermostat. Any suggestions would b great.
    90' Festiva L Plus 'Blue Bomber'
    89' Festiva maroon auto
    93' Festiva red parts car 'future project'
    65' mustang conv
    79 f150 'Big Red'
    97 Explorer 'roadkill' sadly frame rusted out
    Don't ever hit another deer!
    '93 Green L - ' Tiva
      Well hopefully not in the festiva I won't. Hit 5 in my other car
      65' mustang conv
      79 f150 'Big Red'
        Check your VAF plug. The 7 wire plug going to the top of the airbox. I bet when you put things back together it ended up down underneath the airbox and never got plugged back in. I've done it many many times, and it can cause the exact symptoms you described. Also, '90 L-Plus has the best interior of all festivas ever! Love mine!
        No festiva for me ATM...
          The VAF is plugged in
          65' mustang conv
          79 f150 'Big Red'
            With the VAF unplugged, it will only start up and run for a second, then die. Maybe the TPS isn't functioning right?
            -Zack
              I'm at work when I get home ill check it I have a new fuel filter I'm going to try to.
              65' mustang conv
              79 f150 'Big Red'
                Bad VAF I think, had the same problem, replaced, been fine since.
                  After a 70 mph whack check the box and piping for cracks. Then look inside and make
                  sure the door swings freely. Make sure none of the wire looms got pinched or
                  wires pulled from inside plugs where you cannot see.
                    I replaced the box and VAF used thou but it ran after putting it in for 2 weeks b4 problems started.
                    65' mustang conv
                    79 f150 'Big Red'
                      The flap swings freely inside the VAF
                      65' mustang conv
                      79 f150 'Big Red'
                        How's the fuel system? How long did it sit after you hit the deer? Clogged fuel filter could make it act like that.
                          It sat about 2 months but when put back together it drove fine for 2 weeks
                          65' mustang conv
                          79 f150 'Big Red'
                            I just put new fuel filter on it just waiting for the fumes to clear before I start it again
                            65' mustang conv
                            79 f150 'Big Red'
                              New fuel filter and same issue, car runs fine at idle but dies when u apply gas
                              65' mustang conv
                              79 f150 'Big Red'
