I have a 90 L plus that I just finished rebuilding after hitting a deer going 70mph. Ran good but now it dies when you touch the pedel. Car starts and idles fine but you can only barely touch the gas or it dies. Did tune up plugs wires thermostat. Any suggestions would b great.
car dieing
Check your VAF plug. The 7 wire plug going to the top of the airbox. I bet when you put things back together it ended up down underneath the airbox and never got plugged back in. I've done it many many times, and it can cause the exact symptoms you described. Also, '90 L-Plus has the best interior of all festivas ever! Love mine!No festiva for me ATM...
Bad VAF I think, had the same problem, replaced, been fine since.1963 Fairlane - future NSS drag car
After a 70 mph whack check the box and piping for cracks. Then look inside and make
sure the door swings freely. Make sure none of the wire looms got pinched or
wires pulled from inside plugs where you cannot see.Reflex paint by Langeman...Lifted...Tow Rig
