My friend's car, Izzystiva, has a baad oil leak.
It appears to be from the back/end of the engine (near transmission).
I washed the engine then drove a bit to see if I could tell where it was coming from. Fail. Oil was EVERYWHERE again. I think the cooling fan kicks in and blows the leak all over the driver's side of the engine compartment.
I'm not sure what could be leaking so bad in that area. The valve cover gasket is fairly new and not leaking.
I'm thinking it may be the seal behind the distributor? Is there a cam shaft seal there and could it leak bad enough and in a way to cover everything in oil?
